Biz hub 454e
  • antone
    • Oct 2014
    • 344
    Biz hub 454e
    Doc feeder 701 .. paper detection sensor not working ...changed sensor , document board.All the other sensors work..any 411 on this problem.
    Sent from my SM-N920V using Tapatalk
  • allan
    RTFM!!
    • 5462
    Re: Biz hub 454e
    What do you get. Original left on glass?
    Check the ADF original set sensor...
    Unplug the DF to check.
    Whatever
    • antone
      • Oct 2014
      • 344
      Re: Biz hub 454e
      Allan...i hit start nothing happens...chk paper detection sensor not working
        • 14788
        Re: Biz hub 454e
        Have you gone into service mode and checked that DF-701 is selected?
        Also make sure all three connectors are properly seated.
        • antone
          • Oct 2014
          • 344
          Re: Biz hub 454e
          Yes .....did that asap
          • allan
            RTFM!!
            • 5462
            Re: Biz hub 454e
            So if you open and close the DF cover the rollers lift?
            Whatever
            • antone
              • Oct 2014
              • 344
              Re: Biz hub 454e
              Yes that's ok...insert doc...hit start ...rollers don't come down ect
