This machine will not lift and only shows paper empty when the tray is pushed in. It recognizes the tray as the empty light turns on but, there is no operation even when paper is loaded. I replaced the lift motor as once the tray is set, it should lift. I swapped try 1 and 2 to eliminate a bad tray. Any ideas?
Bizhub 552 tray 1 no operation
Re: Bizhub 552 tray 1 no operation
Sent from my Mi A1 using Tapatalk -
[QUOTE=kenpio;590234]Is there paper behind the tray? Did the machine isolate the tray because a malfunction? Look and see if the tray is on the screen. If it is not, you will have to reset the tray.
I can find no paper behind the tray, Like I said, I even swapped tray 1 and 2. The manual states that you should get lift after the tray set sensor is satisfied and I get nothing. Any other ideas?Comment
