konica minolta bizhub c364 streaks in magenta.
  • smiley
    • Aug 2008
    • 615
    good day guys. any one have experience this i have try to swap the drum and clean the laser unit but the white line is still there. pleased see the picture pleased. thanks in advance 20180125_095251.jpg
    there is no glory without sacrifice
  • DDlan
    • Mar 2017
    • 26
    Re: konica minolta bizhub c364 streaks in magenta.
    laser unit new.
    • habik
      • 2013
      How the other halftones look like?
      White voids be Dev unit or laser dirty.
      If belt is worn and has some embossed lines from blade it can do similar lines. You should be able to match them with the rest of colours.
      Sent from portable device using fast cheapset!
      Firmwares HERE
      • smiley
        • Aug 2008
        • 615
        it only happen in magenta color guys. and when i check the developer there is no white line in magnetic roller.
        and the transfer belt is still look good. the total count of this machine is just 15k . 7k on color and 8k on black.
        • habik
          • 2013
          Try initialise and stabilise background reset and full Gradation afterwards.
          Firmwares HERE
          • smiley
            • Aug 2008
            • 615
            thanks for your response friend i will try when i go back to the machine.
            • Ahmed Bushara
              • Mar 2015
              • 26
              Dear Thread
              try to change drum magenta with cyan! if the problem appear on cyan you should try to clean the charger if you can't do that replace the drum unit.
              Thanks and best regards
              Ahmed Bushara
              Electronic Engineering technician
              Mobile: +249-999198804 /+249-123198804
              • 3ktlc
                • Feb 2018
                • 180
                Have had issues with the dev units doing this.
                • REGSIS
                  • May 2016
                  • 435
                  Originally posted by smiley
                  good day guys. any one have experience this i have try to swap the drum and clean the laser unit but the white line is still there. pleased see the picture pleased. thanks in advance [ATTACH=CONFIG]38681[/ATTACH]
                  If the white line is opposite to feed direction then you can eliminate dirt on laser glass or even foggy edges of polygonal mirror.
                  • smiley
                    • Aug 2008
                    • 615
                    to update you guys the void lines is happening in all color but only more visible on magenta color. i see some toner remain in transfer belt. i will try to clean it or replace the cleaning blade and inform you guys if this will solve the problem.
                    • Don N.
                      • Nov 2011
                      • 409
                      Just general FYI: When cost is a factor and if it turns out to be the drum, KTN sells the charger and grid together for under $10. We rebuild these with new drum, blade, grid & chip. Found just cleaning the grids doesn't work or doesn't last. The grid plating seems to burn/flake/peel off, so new grid is needed, especially on older c220 series.
                      • smiley
                        • Aug 2008
                        • 615
                        hello guys after check the itb assy. i find out it was no good already there are some lines on it that cause the void lines in all color. thanks for all your help guys.
