Konica Minolta C450
  • Vesigoth
    • Mar 2008
    • 133
    Konica Minolta C450
    I'm getting a C1183 code on this machine. Any ideas on what this means and how to clear it will be appreciated.
  • ni311
    • May 2008
    • 658
    C1183
    Finishing option Elevator drive malfunction
    Konica Minolta Error Codes - Explanations and Solutions
    • Vesigoth
      • Mar 2008
      • 133
      Minolta C450
      Thanks ni311. I just opened the front door powered down and it reset the code and now working again. Thanks again.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Check the top tray on the finisher. If it is not screwed in properly someone could bump into it, knocking it slightly out of place. This would cause the elevator to over travel, because there is a switch on the side of the elevator, that the tray actuates to make it stop moving.
        • Vesigoth
          • Mar 2008
          • 133
          Konica Minolta C450
          Thanks for the headsup fixthecopier. Good charicature of Nixon.
