Office 365 setup tips
+ More Options
Posts
  • rrrohan
    • Sep 2011
    • 1977
    Just thought Id post this incase anyone else struggles with this
    I had so much drama setting up Office 365 on a C364e. Followed the guide on web exactly
    SMTP address: smtp.office365.com
    Use SSL/TLS: Start TLS
    Port number: 587
    Device Email address:
    SMTP Authentication: ticked
    User ID: fullemail@address.com
    Password: goeshere
    Domain name: required
    but no good constant server connection error
    in the end it was simple.
    Disabled TLS v1.1 and v1.2 and only leave v1 enabled (and SSL v3 as it doesn't hurt to leave it on)
    Under Security - PKI Settings - SSL Settings
    Hopefully this saves someone the frustration
  • hdmr
    Helpdesk Engineer
    • Feb 2013
    • 51
    Re: Office 365 setup tips
    The settings you mentioned disabling etc below, is this something you do on the device or the Office365 configuration?
    Port number: 587
    Password: goeshere
    • tsbservice
      Field tech
      • 8068
      On device.
