Bizhub 363 keeps restarting
  • mihailelea
    • Jan 2018
    • 44
    Hi!
    My client just called me about his Bizhub 363 that won't start.
    When he pushes the Power Button, the display comes on with the hourglass, and after a few seconds it restarts, and keeps doing this forever.
    I've uploaded the video he sent me on youtube:
    I would appreciate any ideas.
    Thank you!
  • kenpio
    • Dec 2015
    • 201
    Re: Bizhub 363 keeps restarting
    Sounds like there is a job hung in the print cue. Unplug the network cable and see if it starts up. If it does, find the PC that the job is in and delete it. That is the only thing that I can think of.
    KEN
    • rrrohan
      • Sep 2011
      • 1977
      tried NV RAM reset?
      • mihailelea
        • Jan 2018
        • 44
        I've removed the network cable, and there is no change.
        I've replaced the 2 SODIMM's with 2 SODIMM's from a Bizhub C360 witch I have in my shop (they are the same) and still no change.
        Not sure what you mean by NV RAM reset. Does the replacing of the SODIMM's qualify as NV RAM reset or is there a procedure for this?
        Also, I've removed the MFP Board (the one witch is the power source), removed all the cables attached to it, and cleaned all the contacts. No change.
        I've unplugged the fuser cable (because I thought that maybe the fuser is drawing too much power or something like that). No change.
        Any ideas are welcome, in the meantime I'll search the manual for the NV RAM procedure, or if someone is kind enough to post it here I would appreciate it.
        Thanks!
        • mincopier
          • Dec 2015
          • 289
          I believe the NVRAM itself is bad and may require replacement. The NVRAM is in the upper right corner of the MFP board. Black plastic surround a battery. Could try removing it and reinserting to the board. A firmware upgrade may not hurt either.
          • mihailelea
            • Jan 2018
            • 44
            Thanks for the idea. I'll try removing and reinserting it first thing in the morning.
            Do you know if the NVRAM from the Bizhub 363 can be replaced with a NVRAM from a Bizhub 223 or 283?
            And about the firmware upgrade, can it be done if the machine doesn't start?
            Thanks again!
            • mincopier
              • Dec 2015
              • 289
              BH223 and 283 are the same family. I believe they will work however counter and serial numbers follow the NVRAM. Works for testing purposes. As for firmware sometimes it will take and other times it does not. Sometime it will fix the issue and other times it does not but it is free.
              • CCC Repair
                • Sep 2014
                • 47
                It sounds to me that you might need to update the firmware
                • mihailelea
                  • Jan 2018
                  • 44
                  I'll try a firmware upgrade in the morning, and I'll also try removing and reinserting the NVRAM.
                  I'll tell you what happens.
                  Thanks everyone for the help!
                  • mihailelea
                    • Jan 2018
                    • 44
                    SOLVED!
                    The firmware update did the job.
                    One of the users told me that the problem occurred when he was trying to scan something thru the network, so maybe kenpio was right and somehow that job was somehow stuck, but removing the network cable didn't fix it.
                    I've updated the firmware from USB and after that it started just fine.
                    • CraigW
                      • Dec 2010
                      • 417
                      Thanks for the info !!
                      • Simza
                        Simza
                        • May 2020
                        • 27
                        Re: Bizhub 363 shows only the hourglass
                        Hi comunity
                        i have problem with bizhub 363, which i have created myself. I have updated the firmware and the elctrecity was gone. Because somebody have take the power switch off.
                        So now i try to start the BH 363, but it shows only the Hourglass continue. please tell me what shuld i do to solve the problem.
                        I will be glad, If anybody can provide me NVRAM Reset tool for Bizhub 363series.
                        Thanks in advance for your help.
                        Have a good time and Stay Safe
                          Originally posted by Simza
                          Hi comunity
                          dead thread grave digger.
                          start your own thread. and you will have to explain your terminology in a clearer manner.
                          • Simza
                            Simza
                            • May 2020
                            • 27
                            Thank you, i will do it currently.
