CODE C13FO Bizhub 210
  • KHAN
    • Aug 2006
    • 261
    I have Bizhub 210 when the copier is ready and i press the START button it shows error C 13FO , I clean the polygon motor it takes rotation fine,but after pressing START it show COPY CANCELED and then error C13FO, PLEASE what i do?
    THANKS.
  • ni311
    • May 2008
    • 658
    Did you clean the polygon motor?! Try to replace the print head unit, I never heard someone to actually manage to fix print heads, I tried myself with no success, just a waste of time.
    Konica Minolta Error Codes - Explanations and Solutions
