Konica Minolta C2452 code
  • JVC
    • Jun 2011
    • 151
    Hello
    I am a Toshiba tech working on a Konica Minolta Bizhub Press C6000L. It came in with a C2451 code. To check if it was in the yellow developer I switched the units around covering the inlets with no change in code. The machine came in with no magenta toner so when the toner came I tried adding a little toner directly into the unit and ended up with a C2452 code then a C2453 code and back to the C2452 code. I would greatly appreciate any suggestions.
    Thank you in advance for any and all help.
  • stuckmx
    • Nov 2017
    • 36
    Re: Konica Minolta C2452 code
    Originally posted by JVC
    Hello
    SENT U A PM
