I've got an issue with a bizhub 750 i wanted to see if anyone else has come across..
Wanting to do a copy of some documents (6 page brochure as A4 pages) using the "separate scan" function. This function works ok while scanning to ftp, however when doing actual copying it will scan the first page then any pages scanned after that the machine will also print while the number of originals on the screen goes up..
When you tell the machine that your finished scanning it will only print the first page that it scanned (and hadn't printed before)
I've attached the couple of pages from the copy operations manual that explain the separate scan function.
