DF617
  • jonpaul
    • Jul 2014
    • 59
    DF617
    We have been having problems with the DF 617 on c220 range where it pulls in multiple sheet .Even after changing all the rollers and giving a good clean it still does the same.Is there an adjustment that I m missing?As ever thanks for any suggestions.
  • Toxic
    • 697
    Re: DF617
    Separation roller replaced?
    Did you put in place correctly separation roller assy spring?
    If i remember good,spring have several pressure positions,try to change.
    Maybe try to replace A0HT561100 Torque limiter if nothing helps.
    • 3ktlc
      • Feb 2018
      • 180
      Re: DF617
      On most KM DF's, the torque limiter seems to cause this issue frequently.
      • Don N.
        • Nov 2011
        • 409
        Re: DF617
        Lower the sep. spring tab under the tray to the bottom, least pressure position.
