hello guys
looking for some help, has someone happened to get this error while printing and a jam occurs?
this is what is happening ----
jam occurs (any jam) --> goes to jam screen indications --> instantly goes to C-3106 (fusing unit not set) (FUSING UNIT WAS NOT REMOVED AT THIS POINT, printing was OK before jamming)... restart --- > C-3106 is gone (This all without even touching the fusing unit at all, just resetting)
so, clearly contact with fusing unit is OK, as its working while printing, and after restarting machine not even opening close door, it is detected
I/O check 25-04 = result is 1 (fusing unit set)
so, in my guess, not the contacts, as stated above
- i flashed firmware again, still happens
- recalled factory data, still happens
has anyone passed thru a similar situation?
could it be PCRB?
thanks for your answers buddies
could it be PCRB?
