C360 with FS-529 finisher
  • scottybbb
    • Dec 2010
    • 126
    Just curious if anyone on here has replaced the exit rollers on a FS-529 finisher. Part number A0U7PP8E01. If so how hard was it. Have one that does not always want to pull the paper back in when sorting or stapling.
  • tech51
    • 846
    Re: C360 with FS-529 finisher
    They're relatively easy to change but unfortunately probably won't totally cure the problem.
    Its usually the two ribbed belts further in that cause this and they are a pain to change.
    One tip though, there are small mylars that are clipped in under the ribbed belt holders.
    They can deform and cause jams.
    Unclip them and throw them away, they do nothing but cause trouble.
    Good luck..
