wierd random image shift on duplexed side
  • zubinn
    • Sep 2017
    • 49
    [Misc] wierd random image shift on duplexed side
    c7000 konica machine, printing simplex is okay.
    Printing duplex on the reverse side the image randomly shifts 5mm inboard perpendicular ( 90 degrees ) to the paper path.
  • allan
    RTFM!!
    • 5462
    Re: wierd random image shift on duplexed side
    You shift is in the "main scan" direction.
    Clean or reconnect the centering sensor.
    Don't know these well.
    Could be skewing before the registration and shifting after the loop.
    Don't these machines jam if the centering is out too far, soft-switch turned off?
    Whatever
    • zubinn
      • Sep 2017
      • 49
      how can i check if the image shift is due to a mechanical issue i.e. the paper physically is shifted higher.
      • allan
        RTFM!!
        • 5462
        check at the paper exit
        Whatever
