Any tips to improve print speed (KM6500)
  • jay3
    • Apr 2017
    • 46
    Any tips to increase print speed?
    On a KM6500, I currently get just under 8ppm with my main job:
    13x19 duplex running mail merge to a master held in fiery controller.
    My noteable settings are:
    Left to right binding (duplex)
    [x] CMYK
    [x] Black detection
    Image Quality = Best
    [X] Text thinning/reversed text enhancement
    Brightness = 100% Normal
    Screen: Dot 1
    [x] Glossy
    [x] Use max C, M, Y density
    sorter mode: collate
    output delivery: Face down - normal order
    I yield about 4000 output pages per toner cartridge.
    • 22804
    Re: Any tips to improve print speed (KM6500)
    [x] CMYK
    [x] Black detection
    Screen: Dot 1
    [x] Glossy
    full color.... 13x19.... DUPLEXED.... -= and =-..... running mail merge? is there a lot of borders/graphics? (toner usage = size + 2sided )
    you bought the wrong machine! it's doing well on that job! I'm assuming Word doc on the merge?
    everything you are trying to do is speed/memory intensive! what you didn't mention is THICKNESS of the media... the thicker the media.. the S L O W E R -= ANY =- Machine will run.
    • guitar9199
      • Sep 2016
      • 1097
      Heidelburg 4-Color industrial press?
      • jay3
        • Apr 2017
        • 46
        148gsm. My piece has to be 13x19 (or larger).
        Was looking at Ryobi 3304HA initially but the max sheet size of 13.x * 17.x kills it.
        Word doc on the mail merge, but I'm printing just the variable data there to a master image stored on fiery using VDS or VDP (whatever it is called).
        • jay3
          • Apr 2017
          • 46
          Longer runs are > 50k+ monthly and get farmed out to commercial printers for now.
          Short runs are 3k-6k (13x19 duplex)... and the dynamic data capability doesn't hurt. Trying to do these in house on the KM6500. Considering getting an army of them because of the price/availability (easily $5k or less each used) and the cos is... not great, but doable I suppose.
          Definitely been looking for the right machine(s) that could handle both in house. A friend has a Xerox 1000 and right at 3 cents (6 cents per piece) for what I'm doing. That would be great, but the Xerox 1000's cost way more... and still couldn't handle the larger job.
            • 22804
            yeah that's a lil heavy to run a "plain" .. anytime you increase the weight of the paper ( and define it in the driver/machine ) you will slow down the machine speed.
              • 22804
              Xerox LOVES their supplies and parts... I HATE XEROX!
