c6500 weird issue
  • afterhours
    • Mar 2017
    • 152
    c6500 weird issue
    Hello, I have a c6500 intermittently going crazy. it will start throwing C2702, C2704, the k developer unit will spit out developer, I get registration sensor malfunctions, etc. Then after working on it for a while it will suddenly start working fine. I found that the process carriage does not close as it used to. The left side seems to close very tight and can only be closed with much effort. Then it opens but I have to pull on it very hard. Any ideas? With the codes I would think its the HV1, but why would it suddenly start working, then not again.
    Please help.
    Im a Loser Baby!!!
  • weeirrr
    • Mar 2018
    • 5
    • Rocini.jr
      • Apr 2013
      • 9
      Re: c6500 weird issue
      Hi... For first, you can take out all items attached to the process carriage... Transfer belt, drums, coronas and Dev Units. After this, close the process and check if it fits ok in position. This will give you an idea about...
      Other thing is taking out the process carriage from the machine, and check the rails. They can be loosen a little, causing this problem. The issues you mencioned seems to be some bad contact on the process carriage.
      • exCSER
        • Mar 2009
        • 98
        If the rails are wearing out, removing all of the weight that they are expected to hold up will probably make them slide in and out of the machine easier, but they do wear out and require replacement sometimes. It does sound like there is a connection problem and bad seating of the process carriage would cause that.
