C-2403 error on C6500
  • Rocini.jr
    • Apr 2013
    • 9
    [Error Code] C-2403 error on C6500
    Hi Everyone!
    Please, I'm looking for some light here... I have the C2403 error on the C6500. Error due to Cyan erase lamp. But I can turn the lamp on by the I/O check mode, as the other colors as well.
    Also, a possible problem could be the ICP13, on the PRCB. I checked it, it's ok.
    Finally, I checked the wiring between the connector back the process carriage to the connector attached to the lamp. I have continuity on both pins.
    Oh, and I using a shim on the process carriage connector, to be shure about the attachment on back, inside the machine.
    After all, Any ideas? TKS!
  • K-3
    service technician
    • Feb 2018
    • 51
    Re: C-2403 error on C6500
    move cyan to another color, if code follows, then replace (el). if still c2403 then you may have a short or pinched wire.
