C280 error DC00 DC30
  • cayyell
    • Feb 2013
    • 82
    Been searching in the site noted is a security related issue
    Found nothing on manual
    When the machine started it throw up code DC00 right away, I can enter service mode use system error clear to clear it and machine can continue to Ready to copy.
    But whenever I try to make any lattice or gradient pattern print it will shows up DC30
    But the scan function still working.
    Need some enlightenment here!
  • mthomasebs
    • May 2017
    • 65
    Re: C280 error DC00 DC30
    Have you tried formatting the HDD?
    C-DC00 is a security based code, usually due to the hdd being corrupted or compromised.
    • cayyell
      • Feb 2013
      • 82
      I tried disable the HDD, but that didn't help.
      • cayyell
        • Feb 2013
        • 82
        I tried remove the HDD, that didn't help too
        • AjitN
          • Mar 2009
          • 287
          What do you mean by that? You are not able to disable HDD OR Disabling HDD did not resolved the problem.
          You need to go to service mode and select HDD not installed (I think in system 2)
          • cayyell
            • Feb 2013
            • 82
            Yes is already set to not installed.
            • Don N.
              • Nov 2011
              • 409
              Assume you've checked relevant security settings and they are off...
              Maybe try physical format (allow plenty of time) then probably have to logical format.
              Just guessing. Also, is there a format SSD option on these? Can't remember.
                • 14501
                • allan
                  RTFM!!
                  • 5462
                  Yes if the HDD is not set the option changes to format SSD.
                  Whatever
                  • allan
                    RTFM!!
                    • 5462
                    Initialize?
                    Whatever
