Any one know what the code C3823 means on the C451?
C451 - code C3823
jimrTags: black and white, c3823, c451, code, connections, fax, fusing unit, power supply, printer control board
jimr
C451
Thanks,
You buy the C451? I have one with 90K color/90K black and white - feed/fax/print/scan - C3823 code, I can't fix the code.Comment
Have you tried to reset the code, using the trouble reset procedure. If you are a tech it is in the service manual. If you are not then call a tech. Fuser codes can cause serious problems.The family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
redime
Try reseating the connectors from the power supply and printer control board, and do a trouble reset... if that doesnt fix it, youre in for a whopper of a bill for a tech to fix it.
Solution IDTAUS0702826EN* Solution Usage 2
DescriptionC-3823 and/or C-3923 are indicated. The connections for the fusing unit, from the power supplies and the printer control board, have been re-seated.SolutionCAUSE: Faild IH power supply (IHPU).SOLUTION: Replace the IHPU (p/n A00J M400 03).
