Di3510 No display on Control Panel
  • thekillerXP
    • May 2018
    • 4
    Hi everyone, I have a Dialta 3510. when i turn it on there is no image in Control Panel, there is sound, I noticed that there is a red light in mainboard that blinks.
  • darry1322
    • Oct 2010
    • 817
    Re: Di3510 No display on Control Panel
    Not a lot of info to go on ... Any fans turning? Green start button lit at all? Is it just the backlight on the screen? Assuming no to all these, it may be a bad MFP board.
    • Gab
      • Aug 2015
      • 670
      Replace display or if you are lucky you can save it.
      Removw display put under and over it 3 sheets of paper and iron it !!! Perhaps it works and i am not jocking .
      • mjunkaged
        • 383
        The Di3510 has a contrast knob, on the control panel, but usually it's built to still show the screen even when dimmed all the way. BUT, if your backlight is dying you could try turning it up, if you haven't already! Just throwing the simple fix out there first! If that doesn't work, see your previous answers. Also, if the 'beep' for the keys is enabled, it should beep if you touch around blindly on your black screen unless it's DEAD.
        • mascan42
          • Oct 2008
          • 484
          Good luck finding either MFP board or a control panel - they haven't made any parts for that model for over four years. Even if you can find one, that's the two most expensive parts in the entire machine. Cheaper to just get a new one.
          • thekillerXP
            • May 2018
            • 4
            Power supply fan is turning, green start button is orange.
            • thekillerXP
              • May 2018
              • 4
              • thekillerXP
                • May 2018
                • 4
                I would like to know if there is a way to test any voltage in display to discard.
                • kenpio
                  • Dec 2015
                  • 201
                  I know that this is simple, but is the sub power switch on the side of the control panel pressed in? Just a thought.
                  KEN
