work1 memory check error minolta +308
  • pern2808
    • Sep 2015
    • 17
    Hi all, have a +308 that as of this morning has been throwing a FC-14 code. Did a memmory check and the result was work1 memory check error NG 000000000 any help appreciated on how to solve. Thanks in advance.
    • 14654
    Re: work1 memory check error minolta +308
    Did you re-seat the memory card? If not start there.
    • pern2808
      • Sep 2015
      • 17
      Removing panel now to try first.
        • 14654
        I just checked a C308 I have in the shop. I had forgotten they called the 1st module Work 0. Unless you have an LK installed you will not have a Work 1 module and it will show NG
        • pern2808
          • Sep 2015
          • 17
          Thanks for update. Any ideas on the FA-14 code?
            • 14654
            Are you an authorized tech?
            Try this,
            Recovery Tool firmware
            A7PU0Y0-F000-GXX-A8
            GXX-A8
            Preventive firmware
            A7PU0Y0-F000-GXX-B0
            GXX-B0
            Otherwise it is either the HDD or MFP board.
            There is a bulletin.
            • pern2808
              • Sep 2015
              • 17
              Try this,
              A7PU0Y0-F000-GXX-A8
              GXX-A8
              Preventive firmware
              A7PU0Y0-F000-GXX-B0
              GXX-B0
              Yes I am will look at bulletin. Have been trying to update the firmware also. Not playing ball. Thanks for all your help. Seems to be ok now data cleared. Reseated dimm and seems ok now
              • tech51
                • 846
                I see the code has gone now but if it comes back try running the complete diagnostic check in state confirmation (if the firmware’s up to date).
                This checks all electrical parts of the machine and then gives you an error code that you can refer to in the manual.
                If it’s not available in state confirmation, do the following.
                Full power off.
                Hold down the sub power switch and then switch on the main power.
                Hold the sub power switch down until the blue data light flashes, then release it.
                The machine should then boot into a diagnostic screen (takes a while to appear though).
                Press start and the diagnostics will run.
                This usually takes a minute or two and will appear to pause when it’s testing the hdd.
                Work1 will always fail unless an expansion memory is fitted.
                It will show the usual ok or ng messages.
                I,ve used this to help diagnose faults and it really helps.
                My money would be on the hard drive.
                Hope this helps you.
                • Bix
                  • Apr 2018
                  • 1421
                  Hello, this problem is repeated very often lately in the Konica Minolta.
                  I understood only that this error is caused by a particular version of Adobe Reader, especially if it uses Chrome.
                  • Copier repairman
                    • Aug 2019
                    • 86
                    will need the following files
                    You can help me.
                    canonrp@naver.com
                    jabattgg@gmail.com
                    A7PU0Y0-F000-GXX-A8
                    Preventive firmware
                    A7PU0Y0-F000-GXX-B0
                    USB-BOOT firmware
                    A7PU0Y0-F000-GG3-54
                    USB-FW firmware
                    A7PU0Y0-F000-GC3-54
                    USB-SATA firmware
                    A7PU0Y0-F000-GXX-A6
