bizhub 362 image
  • Gab
    • Aug 2015
    • 670
    bizhub 362 image
    Before 2 weeks i replaced onl opc drum and blade (customer scrutched it) .
    Developer has made about 60k copies.
    It worked ok for these 2 weeks and the last 2 days when customer turned it on and make the first copies they look
    like those in the attached files. File with name first is the first which copied with name second , second copied etc.
    second.jpgAfter few copies image is ok. Any idea?
  • mo0651
    • 1054
    Re: bizhub 362 image
    Dev unit guide rollers are wearing out. Dev unit or rollers need replaced.
    • Gab
      • Aug 2015
      • 670
      machine has made only 115k copies
        • 14556
        Always change drum and dev at the same time. If the dev spacer rollers are original, you will need to replace them, they wear and start to wobble causing image quality issues. KonMin has replacement rollers available to order. Also, replace the transfer roller with the BH423 roller, it is better made and doesn't wear the drum as quickly.
        • Bix
          • Apr 2018
          • 1421
          The dev generally replaces every 600,000 copies??
          • mo0651
            • 1054
            But the machine itself is like over 8 years old! Are you using OEM toner???
              • 14556
              Lol! Umm, nope. Only 100,000.
              • Bix
                • Apr 2018
                • 1421
                You are right, I have just seen the manual (I have only used newer machines)
                I have seen that the toner filter (developing unit) should also be replaced
                • Gab
                  • Aug 2015
                  • 670
                  [QUOTE=Gab;607579]Before 2 weeks i replaced onl opc drum and blade (customer scrutched it) .
                  It worked ok for these 2 weeks but the last 2 days when customer turned it on and make the first copies they look
                  like those files under .
                  If i leave open machine for about 1 hour it works fine
                  This machine has no spacers in dev unit .
                  Sorry, the machine is biz 361.
                  Also it works fine when i leave it open for about 1 hour. The folloing are the 3 first copies made in that oder.
                  Any idea?
