C-4520 on pro 5501
  • mihaispita
    • Dec 2017
    • 3
    C-4520 on pro 5501
    Hello
    I have this problem on bizhub pro c5501
    C-4520
    Trimis de pe al meu SM-G950F folosind Tapatalk
  • Toxic
    • 697
    Re: C-4520 on pro 5501
    Did you try this procedure?
    • K-3
      service technician
      • Feb 2018
      • 51
      clean the sensors ps8 & ps9 also the gamma sensor and check that the spring for the shutters over the sensors our working correctly, then run adj.
      • mihaispita
        • Dec 2017
        • 3
        I made the adjustments and give me a merror 2.
        I also removed the sensors
        • clint@clintsimonsen.com
          • 120
          With error 2 when they talk about the write unit are they do mean the imaging drum assembly? Or the laser unit
          Sent from my ONEPLUS A6000 using Tapatalk
