Standard web browser for bizhubs?
  • OutlawTorn
    • Aug 2008
    • 189
    Hello all, I have recently installed a bizhub 211 with a network card, however I cannot access the web browser interface. Is it the IP address that I have put into the copier (which isnt working for me) or is there a standard issue IP I should put in?
    Thanks.
  • buster68
    • Nov 2008
    • 181
    make sure that PSWC is enabled.
    • OutlawTorn
      • Aug 2008
      • 189
      PSWC? could you explain a little further? I presume this is something I can enable/disable from the copier itself?
      • WaveyDavey
        • Sep 2008
        • 60
        PSWC (Pagescope web connection) should be enabled by default and yes it is the ip of the engine the one you print to.
        there can be several reasons for this not working external or internal to the device.
        check the network manager has no Proxy service blocking the URL on the LAN
