Can't print to Bizhub 600
  • laserline
    I have two Bizhub 600. One I can print to from a computer and the other I can not. The one I can print to says Print/Copy/Scan under the Device Type and the one I can not print to just says Copy/Scan. I'm assuming I'll need a printer controller for the later one. Can someone give me the part number I need or at least point me in the right direction. Thanks
  • laserline
    Update
    Ok, so it seems like this little device is what enables you to print to the Bizhub 600. This little guy pops in the back of the printer into the circuit board there. Unfortunately, I can't seem to find the part anywhere to order and Konica Minolta service is horrible because everyone tells you you have to call a different number. I need to find this exact part, so I can put it in my other bizhub 600s, so they can print.
    • strider5555
      • Jun 2008
      • 96
      Ok that part is an IC202 print controller and the Item Number is 15NB, which you will have to order from Konica Minolta or Konica Minolta dealer.
      • RockETop
        Curmudgeon at large
        • Apr 2007
        • 171
        Correct. It is not a "part" like a fuser roller.
