How to create overlay file .kfo ?
+ More Options
Posts
  • sbillis
    • Nov 2008
    • 95
    Hello there,
    this is my first post to copytechnet.
    I 'm searching a program to create an overlay file (.kfo) for use with konica-minolta bizhub copiers.
    I google-it but I didn't find anything relevand.
    Can anyone help me please?
  • B0265
    • Jan 2007
    • 718
    You create the overlay files from the printer driver.
    • sbillis
      • Nov 2008
      • 95
      Hi,
      I can create an watermark from printer driver.
      It has an option, below watermark, that you can load your own overlay form file (.kfo).
      I have read the manual and only writes that you must have already made this file.
      With wich program I can create overlay form files (.kfo) ?
      thanks
      • B0265
        • Jan 2007
        • 718
        Open the file you would like to use as an overlay, select print > properties. Under the Stamp/Composition tab select "Create overlay file" (the example is from the C250 Vista driver).
        • sbillis
          • Nov 2008
          • 95
          OK, I got it.
          was so simple if I had read the manual with the right way...
          thank you.
