Bizhub C500 Black Coverage
  • QMS
    • Jul 2008
    • 20
    We appear to be having a consist problem with C500 and black type being very light or washed out. All the PM kits have been installed including drums, toners and new developer. What to check?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Have you checked to see if there is a difference between scanning from glass, adf or an internal print. If you stop in the middle of a print, is the image light on the drum or normal? This would help to narrow it down to a charge or transfer problem.
    • beano
      • 54
      run black halftone at 100 if its uneven then check the black charge wire make sure wire is laying inside the charge unit the right way
      • beano
        • 54
        also check the black transfer roller behind the transfer belt
