Have anyone use C250 toner for C450 model ? can work or not ?
C250 toner
For Bizhub C350 and C450 and also CF2002 and CF3102 you can use the same toner (move it from one cartridge to another with a funnel). I have used toner for C350 in a CF2002.
C350-C450 are an older generation than C250-C252 and have completely different imaging units so the toner is not compatible, so you shouldn't.
Bizhub C250 and C252 use the same toner cartridges.Comment
Don't try it, it won't work. You'll end up with the machine full with toner inside and damage IU's.Comment
Of course, before doing that I've asked people who sell and repair these machines (second hand machines - not K-M dealers). Three different companies. They said the same thing... They are the same machines: CF2002-3102 and Bizhub C350-C450. Also I've used Katun compatible toner for a long time - in CF2002 and Bizhub C250-C252. Also Katun sells the same toner for C350 and C450 (it says on the box)
So, guys if you are not sure what you're saying...Comment
so
1. C250 - C252 use the same toner
2. CF2002 CF3102 C350 C450 use the same toner
but C250 not compatible with C450Comment
My friend, you misunderstood me. I just said that you shouldn't use C450 toner in C250/C252 machine. End of story.
I am sure about what I am saying.
Please read again my post.
Thanks.Comment
