C451 print issue
  • Amincopy
    • Jun 2018
    • 10
    C451 print issue
    hi, the machine is printing some pattern in every print or copy. after a lot printing it will disappear but after machine turning on the issue appear again. can anyone help? thank you
  • habik
    • 2013
    Re: C451 print issue
    Transfer belt is ready to bin.
    Sent from portable device using fast cheapset!
    Firmwares HERE
    • Amincopy
      • Jun 2018
      • 10
      Why it prints same pattern each time?
        • 14796
        Because the transfer belt is worn out and is ready to be replaced.
        • habik
          • 2013
          When cleaning fails, does that. Check manual TO and you'll understand.
          Firmwares HERE
          • 907tec
            • 434
            I would be suspect of the ITB Cleaning motor/gears. Definitely try a different transfer belt first, but I usually see this particular issue when the cleaning assembly itself fails.
            • darry1322
              • Oct 2010
              • 817
              Between print jobs the machine prints color patches on the belt for calibration.
