Minolta cf3102 reset chip IU
  • copys1
    • Aug 2025
    Hello everybody! Hope you are fine ALL of you. I need to reset Minolta cf3102 reset chip IU, 4 colors. Any help is appriciate. Thanks in advance!
  • ni311
    • May 2008
    • 658
    Check out my signature
    Konica Minolta Error Codes - Explanations and Solutions
    • jjw23
      • Sep 2008
      • 36
      send me a message I can get you all four for cheaper than anywhere. I reset them myself.
      • ni311
        • May 2008
        • 658
        Cheaper than this?
        http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&i tem=220312975707
        • jjw23
          • Sep 2008
          • 36
          actually the same price, used to be able to get alot more.
          • Astermarc
            • Mar 2009
            • 46
            How reset IU black from tech. rep. Can help anyone?step by step !!! Thx
            • ni311
              • May 2008
              • 658
              You cannot reset it unless you have a reset device or a chip with life in it.
              • Astermarc
                • Mar 2009
                • 46
                I look to the IU black and I don't see any chip or maybe I don't know where to look. Can u tell me where find it on IU?
                • pepper38_cnd
                  Field Service Manager
                  • Aug 2005
                  • 1075
                  If it is only 4 chips you need you are best to just purchase a set then have the ones you removed sent to some one who can reset them and keep them as a spare. Keep in mind resetting the chip does not fix an IU if it's worn out, which it will eventually be it needs to be replaced. Check out ni311's web site since you are in Greece or mine if you like I am in Canada we both offer Quality Reset Solutions. We both run ads on this site check the banners at the top or the side bar advertising.
                  Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                  Now into Ip TV KODI Boxes
