bizhub c252 Rectangle spot on scans after NVRAM reset
  • ozkan
    • Feb 2018
    • 7
    [Misc] bizhub c252 Rectangle spot on scans after NVRAM reset
    Hi,
    I have just performed NVRAM reset on bizhub c252 to revive it.
    I came to life, there are no issues on network prints, but the copier gives copies with a rectangle dark spot in the middle.
    I am uploading an attachment (and yes I know that this machine has a lot to fix )
    Anybody has any idea what is causing this issue??
  • Toxic
    • 698
    Re: bizhub c252 Rectangle spot on scans after NVRAM reset
    Try to do installation procedure (gradation adjust,date&time setting....)
      agree with redoing the NVRAM ( i hardly ever have done that ) all his init settings were lost..
      time to start over
      • ozkan
        • Feb 2018
        • 7
        The machine was not responding, the black screen issue after hourglass, I had to do NVRAM thing.
        Any specific setting that might end up fixing this???
          yes start over with the installation procedures... just like if it was fresh outta the box.
          • ozkan
            • Feb 2018
            • 7
            Hi, I am clueless what to adjust, tried several random options under service mode with no luck
            Can anybody help me by detailing what to adjust?
            • Toxic
              • 698
              Folow this procedure exactly and it should be ok
              install manual.pdf
