Joining domain "The system is busy. Re-try after a while"
  • patk
    • Jun 2008
    • 56
    Hi
    A customer is reporting that they are trying to join their C308 to local domain but it always fails
  • Bix
    • Apr 2018
    • 1421
    Re: Joining domain "The system is busy. Re-try after a while"
    Hello,
    you have to check that the network settings are correct (ip, subnet, gateway).
    If they are correct, he must try to use Internet Explorer. It happened to me with Chrome / Firefox / Safari and nobody was going. With Internet Explorer yes.
    Also check if you are using http or https.
    • emujo2
      • Mar 2017
      • 1580
      That message is usually associated with a time out error. You might want to experiment with different forms of authentication. You could try a basic ping to verify a connection to the domain server, check for matching times on MFP/DC.Emujo
      • NeoMatrix
        Senior Tech.
        • 3514
        Originally posted by Bix
        Hello,
        If the web browser (Internet Explorer) has been hijacked then other web browsers like FireFox will wrangle with Internet Explorer to try and set itself as the system "default browser". If you find that Internet Explorer is constantly asking to be set as the default browser then you might have a hijack browser or malware running a web browser banner of shorts. If Firefox constantly tries to set itself as the default browser, the firewall software may block it as a malware attempt, and therefore block the normal windows services *.dll files it also uses.
        Try turning off the firewall and see if it makes any difference to the connection.
