KM C258 offsetting issue
  • UKTeam
    • 24
    #16
    Re: KM C258 offsetting issue
    Well its been a while since I posted here, but I still read most weekdays.
    I want to jump in on this thread because I have had exactly this, although it was a C224e.
    Don't ask me why, because the MFP was in a standard office, not too hot, not too cold, not too humid...etc.
    And the issue as you say, shows on the fuller fills.
    You are seeing the remnants of a latent Drum image which is not fully discharged.
    I managed to cure this by reducing the PRIMARY transfer voltage. (Not secondary..!)
    Service Mode - Image Process Adjust - Trans Voltage Fine Adj.
    Start by setting all colours to minimum (-8) and gradually bring them back up a step at a time until the image issue re-occurs.
    Then simply drop back one step until you are happy.
    I believe mine was a mix of -4 and -5.
    It will be interesting to know if this helps you, particularly since this is a C258 Direct contact Charge Drum Unit as opposed to the C224e Air charging...
    regards,
    Mark
    • JDR
      • Jan 2015
      • 82
      #17
      regards,
      Mark
      Looks like you got it !
      I had to set all values to -6 to fix this issue.
      Does it mean HV board is faulty ?
      • UKTeam
        • 24
        #18
        Sorry JDR, had a week off work and missed this...
        Firstly, I'm glad this works for you too, and thanks for the feedback.
        As for the question "Is the HV PCB faulty", no I don't think so.
        Its just some undefined environment issue.
        My 224e is just as happy now as it was a couple of years ago when I changed these settings.
        Don't worry anymore about it..!
        Mark
        • Savian
          • Feb 2021
          • 14
          #19
          regards,
          Mark
          Thank you very much, your post worked excellently. The ghosts desappeared.
          • Kannaneact
            • Jun 2019
            • 1
            #20
            regards,
            Mark
            thq so much
            • nitro912gr
              Advanced User
              • Jan 2021
              • 38
              #21
              this worked for me too, thank you very much.
              The first time it happened I changed drums and it fixed itself but today noticed it again and I barely have the new drums on for a month with very few passes.
              In my case C258 too, I only had to go -1 on each color to fix it.
              • zoor
                • Jul 2019
                • 26
                #22
                regards,
                Mark
                Thanks a lot Mark ยก
