C554e Boots and Wont Make a Copy
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] C554e Boots and Wont Make a Copy
    We have a bizhub C554e that we received with a "bizhub SECURE" sticker on it. Upon first booting it had a message that a format had to be performed because of encryption (I don't remember exactly what it said as that was two weeks ago and I then immediately had a server go down due to Ransomware) so we selected the format option and after the formatting the message went away however it just will not make a color or monochrome copy. It pulls a document through the ADF feeder and in the Jobs List immediately indicates "Stop Printing" Now I am working on it again and have performed the following:
    Ensured ALL Authentication is Off under user Authentication/Account Tracking
    Ensured Factory Default is selected under User for the copy side and the fax/scan side
    Ensured All paper trays are Auto-Size/Auto-Select and Media Type is set to Plain
    Performed a Trouble Reset
    Tech Mode - Performed All Data Clear(copy program/address registration/fax setting/all history/network setting/server data cache)
    Tech Mode - Performed System Error Clear
    Tech Mode - Not Installed and Installed the hard drive under SYSTEM2/HDD
    Tech Mode - Formatted the HDD by Physical and Logical (again)
    Even with had hard drive "Not Installed" under SYSTEM2/HDD in Tech Mode, it will NOT make a copy
    Thank you in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • BR549
    • 111
    Re: C554e Boots and Wont Make a Copy
    Are any of the consumables at end of life? Is life stop disabled?
    • MFPs R Now PCs
      • Jul 2011
      • 156
      Whaaaattt? Yes it copies now, however NOTHING was more than 80%??? Regardless, rookie move on my part and THANK YOU!
