Jam code 13
  • photocopier.technician
    • 27
    Jam code 13
    Hello Friends,
    I am having problem with a Konica Minolta Bizhub C224e. It shows paper jam error 13. I am Kyocera experienced tech now working on some biz hubs. I checked in the service manual and cannot find:
    1. no explanation for jam 13
    2. Identify which sensor is related to the jam 13.
    Please help
  • Schneider
    • Sep 2018
    • 25
    Re: Jam code 13
    Hey
    Generally Konica's will display the jam code as 4 digits like 13-xx. You can also enter service mode and look at the jam code histories for current and previous codes.
    A quick glance at the manual does have codes that start with 13, 13-01 and 13-40 which refer to tray 3 issues. I recommend you look at that history list to get a better scope of what code you are actually getting then refer to back to your manual.
    Best of luck, hope this points you in the right direction.
    • Don N.
      • Nov 2011
      • 409
      Re: Jam code 13
      Whenever there's a doubt about feed tires or 1-way bearings on those shafts & replacing them doesn't cure the jams, we flush the tray & vertical feed clutches with CRC electronics cleaner. $5 at Walmart auto dep't.
