C360 hang up/Freeze
  • inutelkamo
    • Jul 2011
    • 143
    C360 hang up/Freeze
    Hi,
    I have this C360 which is around 3-4 months old, which freezes usually after sleep mode.
    Or when turning on. however i notice some issue which keeps me bugling.
    Freeze and hang up usually happens at afternoon. weird? yahh me to find it weird.
    What i did,
    Update firmware
    Replace memory module
    Check HDD - 100% Life
    Soon to test MFPB.
    Any thoughts? Comments and suggestions are very welcome.
    TIA!
  • Max
    • Oct 2011
    • 555
    Re: C360 hang up/Freeze
    I believe those boxes are a lot older than 3-4 monts. More like 7 years plus. Try factory reset or different HD. Turn off sleep mode?
    • aleksander
      • 378
      Update the firmware
      Sent from my Lenovo K53a48 using Tapatalk
      • muhammadreza
        Lerner
        • Aug 2012
        • 39
        change HDD. After change HDD you have to do logical and physical format. when its done machine will be Ok.
        • Bix
          • Apr 2018
          • 1421
          I think it's an energy saving problem.
          Sometimes it is too invasive
          • inutelkamo
            • Jul 2011
            • 143
            Noted guys!
            Yep! could be older than 4 months in the stock room!
            I have already advise machine for pull out so i can work on it full time.
            Noted those advises, well give an update!
            • Bix
              • Apr 2018
              • 1421
              Hi, I'll give you some skills that solved similar problems:
              1. Service Mode> System 1> Sleep on / off choice setting> Permit.
              2. Enter the administrator menu.
              3. Choose menu number 1 "System Settings".
              4. Choose "Power Supply / Power Save".
              Now you have to set this up:
              - Low consumption settings: as you want (I suggest you stay high).
              - Pause mode: no.
              - Activate energy saving: normal.
              - Power consumption in pause mode: active.
              5. Weekly timer setting: set to ON.
              - Select on Pause.
              - Set the weekly timer OFF.
              Some names of the menu may be slightly different, however similar to what I wrote.
              Let me know!
              • inutelkamo
                • Jul 2011
                • 143
                UPDATE!
                UPDATE!
                UPDATE!
                machine was pulled out from client to be observed in the office.
                Yesterday: Working fine!
                Today: Upon turning ON this morning, it did hang up in the Logo.
                So decided to test MFPB.
                Installing new mfpb requires new Firmware right?
                how ever upon plugging the USB with firmware, it did turn on until the beep(Hour Glass), then screen blacks out..
                Blue and red light on the scanner, and red light on the start button..
                any thoughts?
                any proper procedure in replacing mfpb? i did lost my service manual. Do it need some like nvram back up before replacing?
                could be a HDD issue since HDD is required during firmware update?
                or it could be SSD issue?
                Thoughts are very much welcome.
                • mdtrinh
                  • Aug 2010
                  • 68
                  Originally posted by inutelkamo
                  UPDATE!
                  UPDATE!
                  UPDATE!
                  any thoughts?
                  Try NVRAM, it worked for me.
                  Hope this help
                  • docdot69
                    • May 2016
                    • 53
                    did you checked the cable plugged into monitor? try to re-plug it. i know it sound silly, but usually when users rotate monitor or grab it from the right side, the cable get loose and may not stick properly. just try it before mfpb.
