biz 501
  • Gab
    • Aug 2015
    • 671
    biz 501
    In this machine previous service replaced developer before 50k copies (only developer) . fter 50k copies i replaced drum , executed drum counter clear . It worked fine for about a week and then when they turn on machine have some image problems. Solid dark line at one side then after some copies at some lines image is more intense . And after some copies image is ok and remains ok till next day.
    Any ideaa where the problem is?
  • Gab
    • Aug 2015
    • 671
    Re: biz 501
    Sorry, machine is 362 also the same image for copinyg and printing
    • Gab
      • Aug 2015
      • 671
      Re: biz 501
      sorry , sorry again , machine is 360
      • Toxic
        • 697
        Re: biz 501
        Did you check/clean/replace charge corona?
        After that check drum,cleaning blade,developing roller...
        It make sense to follow procedure and replace drum,developer,corona... together.
