Grey shrinking triangle KM bizhub pro c6500
  • JAkelar
    • Mar 2018
    • 18
    [Misc] Grey shrinking triangle KM bizhub pro c6500
    Konica Minolta
    Bizhub C6500
    when printing it has a grey triangle that will shrink with each continuous print, but returns for each new print event.
    does anyone know what causes this?
  • qbert69
    • Mar 2013
    • 1152
    Re: Grey shrinking triangle KM bizhub pro c6500
    Originally posted by JAkelar
    Konica Minolta
    Bizhub C6500
    Perhaps bad/worn drum cleaning blade?...or a bad corona wire/scorotron grid?![emoji848]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • tech51
      • 846
      Have you replaced anything yet? Looks like the developer unit to me.
      • JAkelar
        • Mar 2018
        • 18
        so i havent checked the cleaning blades.. i did swap the corona wire and scorotron things to see if the issue moved to a different color and it did not.
        is there a way to check the blades without complete dissassembly?
        • JAkelar
          • Mar 2018
          • 18
          does it.. That is what i was thinking and i told her that. . but i wasnt sure.
          • raplma
            • Mar 2017
            • 139
            We had something not too dissimilar to this on a c5501.
            It was dev related, although what solved the issue in this case was changing the toner.
            In the course of checking through items, removed the black toner bottle and noticed that the tabs on the cap had been trimmed off, presumably a bottle for another machine made to fit.
            There was no telling what the bottle was, so put the correct toner in and neither machine nor operator did it again.
            Your's on the other hand may not be so simple
            Mark
