Bizhub 367 , Reset Tools
  • pinspin
    • Oct 2011
    • 156
    [Misc] Bizhub 367 , Reset Tools
    Hello . We did not find in Service Manual how to use Reset Tools . We will be grateful for any advices .
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 367 , Reset Tools
    Use chips or replace the ICP's on the current chips. If you have a tool its probably a reset fuse. But no need to reset these units.
    Whatever
    • allan
      RTFM!!
      • 5462
      Oops reset like the software tool?
      Whatever
      • pinspin
        • Oct 2011
        • 156
        We need to reset the machine parameters (nvram etc.), exception for Total Counter.
        • allan
          RTFM!!
          • 5462
          Why? Wont an initialize do the trick?
          Whatever
          • allan
            RTFM!!
            • 5462
            Or is it a brick?
            Whatever
            • pinspin
              • Oct 2011
              • 156
              Or is it a brick?
              The copier freezes sometimes.
              • acusso1234
                Tecnico
                • Dec 2008
                • 250
                Are you sure?
                I have a bizhub 287 asking for a new drum.
                Do not display is the choice in service mode.
                Manual states that there are two settings via soft switch to change also. Tried that but no go. Firmware is one year old.
                Ideas?
                Sorry to hijack the post.
                Aldo
                ... In the minute that you're thinking of giving up, think about why you lasted so long ...
                • allan
                  RTFM!!
                  • 5462
                  Originally posted by acusso1234
                  Are you sure?
                  Ideas?
                  Aldo
                  The switches needs to be changed before the life runs out.
                  Whatever
                  • allan
                    RTFM!!
                    • 5462
                    Are there any error codes in history?
                    Whatever
                    • pinspin
                      • Oct 2011
                      • 156
                      Nope
                      • allan
                        RTFM!!
                        • 5462
                        Disconnect HDD if installed to test and if you can swop out the ram. But firmware should be done first.
                        Whatever
