film on lower fixing roller biz hub 751
  • inkstrum
    • Apr 2011
    • 14
    Bizhub 751 lower fixing roller builds up toner film. Both upper and lower rollers have been recently been replaced. Sometimes it happens quickly and sometimes not. It's easily removed from the roller and the paper it falls on, but consumes time. I'm not very familiar with these machines so would appreciate help on this.
  • 3ktlc
    • Feb 2018
    • 180
    Re: film on lower fixing roller biz hub 751
    Generic toner?
    • 907tec
      • 434
      Are you replacing the fuser web, as well? Are you sure the fuser web is turning?
      • allan
        RTFM!!
        • 5462
        Is the green handle up for the fuser pressure?
        The handle wears and the door can close with it down.
        Whatever
        • 3ktlc
          • Feb 2018
          • 180
          Also, check the gears for the web. A tooth might be broken.
