B554e no toner on page
  • rrrohan
    • Sep 2011
    • 1977
    B554e prints nothing, copies nothing.
    Drum and Dev changed as were due. no change.
    Drum confirmed to rotate.
    Stop mid print and no image on Drum
    Load checked Laser (Print Head) and it spins up, so think thats fine.
    Get no C codes just P codes due to failed stabilisation.
    Im thinking either Print head or HV Board
    Under time pressure to solve this, im thinking the HV Board, do you concur
    thanks?
    • 14735
    Re: B554e no toner on page
    thanks?
    If you had the transfer belt out I would make sure it is installed correctly.
    Also check that there isn't something physically blocking the printhead.
    HV board, as you stated, could also be the culprit.
    • allan
      RTFM!!
      • 5462
      no data to the print head does this on some KM machines
      Whatever
      • Zesti
        • Jun 2009
        • 308
        I hope you have re-seated HV and PH connectors already. If no result, try changing 1 by 1.
        No data to PH is Worst case.
        • Zesti
          • Jun 2009
          • 308
          • rrrohan
            • Sep 2011
            • 1977
            Ended up being the high voltage board
            • CraigW
              • Dec 2010
              • 417
              Thanks for update....
              • JR2ALTA
                • Feb 2010
                • 2033
                In my experience a bad HV board causes washed out prints not completely blank. So good to know, thanks.
                • rrrohan
                  • Sep 2011
                  • 1977
                  sometimes they just epicly fail and dont function at all i guess *shrugs*
                  hopefully it helps the next guy
