C550 Multiple batch scan
  • btg
    • Jan 2008
    • 14
    Hey guys,
    A quick question regarding the scan feature. I have 50 seperate documents i want to scan but dont want to stand by the copier and insert 50 scan jobs. Is there any way i can get the c550 to separate the documents? I know certain canon products allow you to insert a barcoded page that registers with the scanner as a document separator page so that a new file is created each time one of those pages are scanned.
    Does anyone know if the c550 can do a similar function?
  • B0265
    • Jan 2007
    • 718
    In "Scan Settings" > "File type", select "Single page".
    • btg
      • Jan 2008
      • 14
      sorry that answer confused me a little.. doesnt single page just mean i can only scan 1 page at a time?
      could you pls elaborate?
      • dogsbody
        • Jun 2007
        • 289
        single pge is exactly, that one file for each page scanned. I am pretty sure that that omnipage pro (konica package it here as "Unity Desktop" along with Paper Port don't know about anywhere else) would do what you want.
        The force will be with you always.
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Scan it as a jpeg you will end up with 50 pictures.
          Now into Ip TV KODI Boxes
          • pepper38_cnd
            • Aug 2005
            • 1075
            It is just like dogsbody said. It doesn't get any easier than that. Here it is right out of the owners manual.
            • btg
              • Jan 2008
              • 14
              Thanks for the replies guys,
              I'll look into this further especially down the unity desktop route because even though my batch contains approx 50 separate documents each document can be 3-4 pages long, hence the single page setting would put me in a similar problem where i have to combine lots of single pages to create each document rather than separate one large document to multiple smaller ones.
              • bigmark
                • Sep 2008
                • 39
                the other option you have is if you can still find a copy of the alchemy package some place. Alchemy will allow you to print bar coded pages in between the pages of the seperate jobs and then file them into the correct portion of the alchemy database. Only problem is I believe Konica may have stopped supporting and selling Alchemy. Not a 100% on that one though.
                • bigmark
                  • Sep 2008
                  • 39
