Konica Minolta C654e - multiple errors
  • zstekovic
    • Oct 2018
    • 10
    [Misc] Konica Minolta C654e - multiple errors
    Hello everybody!
    I have Konica Minolta C654e with FS-535, SD-512 and PK-521 (2/3 holes) - it printed for whole 2 days at my office.
    Yesterday I got error C E004, and because I'm not under contract (bought machine for cheep) repair cost 10x more than machine
    (board replacement and stuff).
    First I try holding reset and reset trouble codes - did not help - then I priced to see if memory module moved during move of the machine - no - it's fine.
    Then I check all the board connectors that I could find, they are ok.
    So I tray Stop 00 Stop 01, because I don't have anything to lose at this point.
    Format HDD, check memory, initialize whole system.
    In short, reset everything I could find, and error C E004 despaired!
    Excellent!
    + HDD is OK
    + memory is OK
    + communication and copying SSD>HDD is OK
    I reboot the machine, and I can scan and copy. That's progress.
    But then:
    ATENTION1
    - Preparing SCAN/FAX
    - Preparing User box
    - Bypass Tray cannot be used (it's little bit wobbly on right/back side - I will check that later)
    So I think that I need to reinitialize everything, and I need this forum help.
    I can connect to web interface, but if i try to log in as the admin it say:
    - It is not possible to login now.
    I don't have any option to change network preferences in admin menu.
    Also I needed to reset admin password in Tech mode with stop - zero (0) - C - 5.
    Now I can login on machine as admin, but lot of panels are missing.
    How screwed I'm?
    Please help.
    Thanks!
