Konica Bizhub C458 Jam Duplex
  • Sheshonq
    • Jun 2018
    • 10
    I have random problems with duplex jams: 93-10, 32-01, 32-05, 30-03. Any idea ?
  • Sheshonq
    • Jun 2018
    • 10
    Re: Konica Bizhub C458 Jam Duplex
    I checked the solenoid motor.
    • Sheshonq
      • Jun 2018
      • 10
      • Sheshonq
        • Jun 2018
        • 10
        It continues...
        • Sheshonq
          • Jun 2018
          • 10
          • Sheshonq
            • Jun 2018
            • 10
            Temp. & Humidity :
            It happens when the printer has only 130,000 copies.
            • Norwaytech
              • Oct 2012
              • 7
              I got a C458 . jamode 9310 ( a lot of them, some 9202 and 3003. the coper has only 16000 printsand 100 james in total
              I swapped over the hole unit in page 48 in the parts guidemanual - possibly problems with the stepper motor A2X0M10600 (M5) or one of the Photointerrupter.
              • allan
                RTFM!!
                • 5459
                There is a weak plastic bushing on the front of the switchback unit causing a belt to skip. Normally some noise from the exit section.
                If that is the case modify by installing a brass bushing. Some drilling and some glue involved.
                Whatever
                • Sheshonq
                  • Jun 2018
                  • 10
                  Do you mean i have to replace plastic bushing by brass bushing ? Where do i have to drill ? i don't understand. The glue, what for ?
                  • DK-tech
                    • Apr 2021
                    • 25
                    I just had 93-10 on a C558. I adjusted the right door so it tilted counter clockwise. Seems like it did the trick.
