Konica Minolta C224e Paper size detecting as 11x17
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Konica Minolta C224e Paper size detecting as 11x17
    Konica Minolta C224e from Tray2 Paper size detecting as 11x17
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Konica Minolta C224e Paper size detecting as 11x17
    [QUOTE=musthafavi;715208]Konica Minolta C224e from Tray2 Paper size detecting
    Change parts below
      • 14573
      What size paper is in the tray? What have you done to troubleshoot problem?
      • tech51
        • 846
        Usually a broken wire on the connector as it plugs into the size block. Easily repairable if you know how to use a soldering iron.
        • musthafavi
          • Aug 2017
          • 76
          Paper size in the tray : A3
            what have you done to correct the issue?
            you need to provide more info if you want a resolve
            • musthafavi
              • Aug 2017
              • 76
              Thanks for your replay, the issue has been solved,
              Feed roller has been changed and its working fine now
                ok a *TIP* anytime you have 'size mismatch' 'false/ghost jams'
                AT LEAST CLEAN THE ROLLERS.. basics.. EVEN in the USERS manual!
                • allan
                  RTFM!!
                  • 5462
                  Not that common but had that before where the wire breaks of right next to the connector.
                  Still not sure how a feed roller fixes a tray size detection problem??
                  Hate those timing jams J-99XX but it point you in the right direction if the machine tells
                  you to check paper size in the tray.
                  Whatever
                  • musthafavi
                    • Aug 2017
                    • 76
                    you to check the paper size in the tray.
                    Before changing the feed roller, I cleaned the paper tray, feed roller and it keeps continue getting the same paper size
                    and finally, changed both feed roller and its working fine
                      doesn't fit logic for me...
                      unless moving trays got a sensor working...
                      • musthafavi
                        • Aug 2017
                        • 76
                        Yes you are right, again its revert back to 11X7 size,
                        after restarting the printer its detect as A3, after a while or while loading new paper it's detecting as 11x7
                        Please need your suggestions and support to short out this issue, what I will do next
                        • allan
                          RTFM!!
                          • 5462
                          Eish... Its the Width detection sensor on the sensor holder its broken or the wire is broken use a screwdriver to remove the sensor holder to inspect the holder and the sensors the connector and the cable.
                          Whatever
                          • musthafavi
                            • Aug 2017
                            • 76
                            could you please explain, where it is located in Tray2
                            • allan
                              RTFM!!
                              • 5462
                              If you remove the tray at the back inside the machine.
                              Could even find a piece of paper in there.
                              Whatever
