Di350 duplex
  • Silvio Ribeiro
    • May 2008
    • 34
    Di350 duplex
    I have a Di350 when installing the module for duplex she jammed in the fuser output, please someone help me, thank you.
  • tonerspot
    • Nov 2008
    • 79
    did you have rotation on the exit rollers ?
    • Silvio Ribeiro
      • May 2008
      • 34
      How so? I did not understand how that rotation? better explain to me please.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        On a Minolta 250, 251, 350 or 351, when you put a duplexer on the machine, the machine uses the small motor in the duplexer to drive the fuser. The motor is at the top, inside the duplex unit and has most likely gone bad. If you take the duplexer off of the machine, and it stops jamming, then the problem is the motor.
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          I've also had the PCB's fail in the duplexer. Best bet is probably to swap the duplex unit out with another one before ordering parts.
          • oce bill
            • Nov 2008
            • 24
            Hi on the DI350 duplex is a option, so if you fit a duplex you have to remove a piece of tape covering the exit from the fuser where the paper would enter the duplex,
            it's about 10 inchs long and quarter of a inch wide and the same colour as the machine covers so you need to look closely,
            GG
            • Hansoon
              • Sep 2007
              • 3391
              Don't know in the rest of the world but in our region the Di-350 came complete with Duplex Unit. Only the Di-250 needed this as an option.
              We had Duplex units causing the fuser roller drive to stop for unknown reasons, maybe weak motor, perhaps gears or fuser roller bushings binding a little more than usual, maybe a bit of all together. However by changing the Duplex Unit it was most of the time solved.
              Hans
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                healpe
                Hans
                hi all do you know RISO RP-3500?
                I NEED TO KNOW THE SPECIFICATIONS
                BEST TECHNICIAN . NICE PEOPLE .
                • Silvio Ribeiro
                  • May 2008
                  • 34
                  Friend you've tried on Google? I can not help you, because I never worked with laughter, but good luck.
                  • zaza
                    MECANOGRAPHE
                    • Mar 2008
                    • 1095
                    thank's
                    hi friend silvio no probleme l have more friend technician in our group ..so don't afraid for me.
                    • Silvio Ribeiro
                      • May 2008
                      • 34
                      My friend Zaza excuse me, I did not understand you, but I do not speak English, I use a translator to communicate me.
                      • Hansoon
                        • Sep 2007
                        • 3391
                        • zaza
                          MECANOGRAPHE
                          • Mar 2008
                          • 1095
                          hi friend
                          hi friend silvio it's not probleme you are my friend technician and l need open with you a new friend chip relation ...you and me and more other friend technician in this site need to collaborate together to helpfulness for anything in copiers machine . so nice to meet you my friend silvio .
