Can you export user boxes on Konica Machines
  • progoffice
    • Nov 2008
    • 337
    We are in the process of setting up several Konica machines all the same way. I know it's possible to export almost all settings via USB; however, I don't think this exports User Boxes. I know Kyocera machines can do it. I don't care about the content of the User Box, just the creation of the boxes. Maybe the Data Administrator can do it?
  • K-3
    service technician
    • Feb 2018
    • 51
    Re: Can you export user boxes on Konica Machines
    i believe you are right with data administrator
    • tech51
      • 845
      • progoffice
        • Nov 2008
        • 337
        That would be awesome if you can find out which bulletin number references this enhanced export mode.
        • mincopier
          • Dec 2015
          • 289
          The following only works on "4" series machines and newer. Not sure if this will move the User boxes or not as we have very few that actually use this feature. It also will not copy the IP, Subnet, and Gateway address's.
          Service mode
          System 2
          Software Switches
          Choose switch 72
          Change to Hex 04
          Fix
          End until out of service mode
          Administrator mode
          Scroll right until external memory backup, might be External Memory
          Here is the import/export options. Use export on the old machine to load the thumb drive and import on the new machine to load the machine. Must use a password, keep it simple such as 1234.
            • 30609
            Yes you can export and import user boxes names
            But NOT the contents of the user boxes
            • progoffice
              • Nov 2008
              • 337
              I'm familiar with the switch 72 HEX 04 setting, but how do you export User Box names? I don't think this option is available even after enabling these settings. Is there another switch setting to enable this feature?
                • 30609
                Never had to enable a hex switch switch , it was in the admin tool
                • emujo2
                  • Mar 2017
                  • 1579
                  I was forced to do this once for a customer. Had to use PSWC to download all the box files, then push them back to the new device.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    Odd I've never had it enabled out of the box. If they are now enabling it by default that's good, why hide such a good feature
                    • progoffice
                      • Nov 2008
                      • 337
                      I don't see the option to export boxes using PSWC. Is this located under Import/Export? If so, which option refers to Boxes?
                        8T6 4T7
                        • 15206
                        I don't know of any way to export user boxes. You just have to recreate them on the new machine as far as I know.
                        • allan
                          RTFM!!
                          • 5462
                          Had the task before. About 20 user boxes full of stuff. Sent using address book and FTP location from the panel. But did not know any better.
                          Lost all the print job settings that mattered on some of the documents.
                          Can use Box Operator. But that is only box contents.
                          Whatever
