magicolor 1680MF "Caution Process Error - Belt Clear By Cover"
  • KapeKopyTek
    • Nov 2013
    • 284
    [Error Code] magicolor 1680MF "Caution Process Error - Belt Clear By Cover"
    This little gem has 11669 prints, was dropped off at the shop for evaluation, was "working intermittently". When powered up, I get this above mentioned error message. The scanner goes to home position ok, so that seems to be free. Nothing in the manuals referring to this message, and the only solutions online are to reboot, which does not clear the problem on this particular machine. Anyone seen/resolved this before? Thanks in advance.
    • 15068
    Re: magicolor 1680MF "Caution Process Error - Belt Clear By Cover"
    • mjunkaged
      • 387
      IF you have a used or new image cartridge from the same model series, it may be worth trying to swap that. The belt mentioned in the message is inside of that cartridge you pull out of the machine to remove jams.
      I own a 1690, these machines sold NEW with toner for 220 dollars with free shipping at one site.
      • KapeKopyTek
        • Nov 2013
        • 284
        Dang, guess I need to brush up on my manual searches. Thank you. The K toner is down to 8% and there is the hint of a void down the middle of the page. New K toner and imaging unit should do the trick then. Cheers!
        • KapeKopyTek
          • Nov 2013
          • 284
          We don't have any kicking around, but thanks. Cheers!
          • mjunkaged
            • 387
            I hope you try toner first then belt, I'm curious if it was just low toner, or if Image unit (belt) is at fault.
            Can you post a follow up?
            • KapeKopyTek
              • Nov 2013
              • 284
              I will try, I have to contact the customer and give him pricing, not sure if he wants to put any money into it at all. He's getting an evaluation at no charge.
              • mjunkaged
                • 387
                Maybe a parts machine for you.
