C6501 DU-104 Drums failing early C-2824 C2824
  • methogod
    • Dec 2008
    • 921
    Anyone seen DU-104 drum units failing early...
    been through 3 drums in less then a 1.5 PM Cycles...
    Always the black drum.
    Issue moves with drum, like the surface wont hold charge anymore.
    Runs in lower humidity environment.
    C2824 Once in a while
    2.5M clean machine, super well taken care of....
    HV or Erase Lamps?
    Anything i should look for?
