KM Bizhub c350 question
  • scooter
    • Jan 2007
    • 19
    We have fuzzy printing in the middle of our page. 3" wide aprox. and the whole lenght of 17"
    I changed the image transfer roller and the fusing unit,(because it was needed) and that made no difference.
    Does anyone have an idea what i should do/
    Thanks for your help
    Skye
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Your LED arrays are probably dirty - clean them with the provided stick and if that does not fix it entirely clean the leds with a slightly damp (water) cloth.
    KEndall.
    If you are hitting your head up against a wall it always feels better when you stop.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Malfunctioning paper loop sensor PC4, Repair or replace sensor
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • dbrownlee
        • Sep 2005
        • 197
        You might want to try making copies in single colors, one at a time (CMYK.) That can narrow the problem down to imaging unit, LED array, etc. I have had to change the LED array- according to tech support, it is not unusual after 500K. If it does it on all colors, I would look at the image transfer belt.
        GO TIGERS!!
        • CMB
          KonicaMinolta Tech.
          • Mar 2005
          • 457
          run halftone test patterns for all 4 colors at about 128% density and try and narrow it down to which image unit- if it is a image unit. also try cleaning the led's.
          • fixerboy
            • Nov 2006
            • 17
            part neede
            Skye
            change the transfer belt ,also check each IU unit run each color
