c250 all but died
  • darrengal8
    • Aug 2025
    c250 all but died
    Hi
    We have a bizhub c250 that is all but died.
    when you turn it on you hear a click, the print key lights orange and nothing else at all, no lcd at all.
    we have change the power supply board on the left hand side, but this has not done anything. we think it could be the c board under the platten glass. has any body had this fault and can give us some advice.
    Regard Darren
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    We had one did the same thing turned out to be PWB-M, item 25 in the pic below. But it could be the board you are considering, we did tried that one first at the recomendation of tech support.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • konikilla
      • Nov 2008
      • 43
      Hi Darren,
      Did you have any luck, we have a the very same issue and are at loss. we have changed the power supply, the mfp sys, the mc-sif and pwb-m as pepper suggested above, we also checked the mechanical meter, and replaced the fuser, the image belt, the toners, and all the image units??????
      • darrengal8
        dead c250
        Hi
        After many hours checking, it turned out to be pwb-m
        • Benedict
          OA techy
          • Aug 2008
          • 39
          OA technician
          Hi please do me a favour and put that board back and do a NVRAM recovery and do necessary firmware updates and bit switch changes have had these machines freeze with no displays and error codes guys replaced the boards machine works tested boards in workshop just required the nvram recovery to be done lots of money wasted give it a shot if it works cool if not tough but I reckon its worth the effort$$$$$$$$.
          • mitchl
            • Apr 2007
            • 501
            That should have been the first thing done, sounds to me like a classic NVRAM crash as I have seen numerous machines like this and its always the evil NVRAM.
            • didspip
              • Sep 2008
              • 11
              Hi,
              Have you tried disconnecting the Hard Drive?
              I have had several machines with display problems related to a dodgy HDD.
              You will get an error if it is the HDD and you have un plugged it, just un install it via service mode.
              Also considder the working Ram.
              If you plug a CF card in and turn it on do you get the firmware update screen?
              If so it is a good indication that your MFP and control pannel are OK.
              • Benedict
                OA techy
                • Aug 2008
                • 39
                OA technician
                Hi guy
                This be a possibility but also check that HDD is connected properly and it has been formatted but I will suggest start with the firmware first before going for hardware much quicker and cheaper.An expensive tech is not what managers want be a fixer not just a parts fitter.
                • didspip
                  • Sep 2008
                  • 11
                  Who Said Anything About Fitting Parts ????
                  • Benedict
                    OA techy
                    • Aug 2008
                    • 39
                    OA technician
                    EEZY guy have a sweet day.
